2013-12-27, 8:13
2013-12-27, 8:14
Sadly all the patterened parts are missing currently.
2014-03-05, 9:51
70127 - Wolf Legend Beast (Legends of Chima)
![[Image: 70127.png]](http://www.brickshelf.com/gallery/Philo/SetModels/Set70127/70127.png)
Missing: Stickers.
The L3B file contains groups, I guess it would not be too hard to convert this into a proper mpd...
Missing: Stickers.
2014-03-29, 9:23
Philo Wrote:I guess it would not be too hard to convert this into a proper mpd
Maybe this can be done by an application
It looks to me that only the "Group" portions have to be put into an ldr file and the content of "Group" substituted by that ldr file with an identity matrix and zero offset.
If this is the case also the other way should be possible to do automatically.
The result would be an application called l3b2mpd or mpd2l3b.
I am right?
But there are several special commands in the l3b format that I am not aware of and what it will do. So I would need some input how to convert or substitude those commands.
2014-04-03, 13:12
Maybe a bit off topic, but something like l3b2mpd would be an amazing piece of software for me.
My current workflow for making building instructions is building the model in SR3D Builder and use the groups as sub-models. Then, I export every group one by one to a seperate file (SR3D paid functionality). Then, I import everything in MLcad to make the .mpd (so the submodels actually become submodels in LPub) and add, if needed, buffer exhange, ghosting, arrows etc.
It works very well, except that I have to export every submodel one by one by hand.
If you could make something like l3b2mpd it would be very useful for me.
The groups commands aren't very difficult to use:
Note: I only found this out by modifying these things in the past, but I've never checked anything of the following with Sergio if it's correct, but I'm pretty sure.
At the beginning of a l3b document is the
Where,
The grouplist contains all the groups. Let's take and example:
Where,
Then, in the model itself you can find the group commands. Those are very simple and look like this:
Where,
Here you can see there are multiple parts belonging to group 4 and 5, but they are split across the file. Group 0 is also thrown in there, things in group 0 don't have a group.
Again, it would be nice if you could make something like l3b2mpd. If you have anymore questions, feel free to ask
0 GROUPSLIST 1
0 ENDGROUP
- 0 defines that this is a command and not a part
- grouplist defines the grouplist
- 1 is the grouplist number (although it's quite useles for now, since a model can have only 1 group, but who knows what will come in a future update)
0 GR Left-arm 6 3 False
- GR defines that this is a group
- Left-arm is the group name (user created)
- 6 is the group number (automaticly created)
- 3 defines the parent group. So, in this case group 3 would be the parent of group this group, group 6. If the parent group is set to 0, it isn't a child group, but a parent/base group.
- false defines that this groups must be displayed. It's quite unintuitive, because TRUE means that the group shouldn't be displayed.
0 GROUP 11
- GROUP is the command name
- Is the group number
0 GROUP 4
1 0 -140 -140 140 0 1 0 -1 0 0 0 0 1 32013.DAT
1 4 -140 -140 110 0 1 0 0 0 -1 -1 0 0 32062.DAT
0 GROUP 5
1 0 -140 -140 90 0 1 0 -1 0 0 0 0 1 59443.DAT
1 4 -140 -140 70 0 1 0 0 0 -1 -1 0 0 32062.DAT
0 GROUP 4
1 0 -140 -140 40 0 1 0 1 0 0 0 0 -1 32016.DAT
1 4 -151.4804 -140 12.28358 -0.3826802 0.9238809 0 0 0 -1 -0.9238809 -0.3826802 0 32062.DAT
0 GROUP 5
0 GROUP 0
1 0 -155.3072 -140 3.044769 -0.3826802 -0.9238808 0 0 0 1 -0.9238806 0.3826802 0 6536.DAT
1 0 -173.7849 -150 10.69838 0 -0.9238808 -0.3826803 -1 0 0 0 0.3826802 -0.9238809 2780.DAT
0 GROUP 4
1 0 -139.3538 -142.3763 200 0.9702954 -0.2419221 0 0.2419221 0.9702956 0 0 0 1 64393.DAT
2014-04-03, 15:11
Thanks for clarifying all this!
Indeed I used exactly the same method as you to create the EV3 bonus models building instructions...
"true defines that this groups must be hidden"...
Quote:0 defines that this is a command and not a part0 is one of the 6 types of lines in any LDraw file, introducing comments or meta commands.
Quote:false defines that this groups must be displayed. It's quite unintuitive, because TRUE means that the group shouldn't be displayed.It becomes more logical if you change "displayed" with "hidden"
2014-04-03, 15:26
Ok, there seems to be an interest in this.
Please do not expect that tool within the next days
Maybe I integrate this into MPDCenter as "Import from l3b".
I will inform you about progress in this matter in this thread.
2014-05-09, 22:00
I have done the first steps on this matter. It seems to work fine, but some additional test needs to be done.
It will be integrated in MPDCenter.
2017-02-10, 13:55
Made an OMR compatible MPD for this one.
