2013-12-15, 20:25
Hej everybody,
the things getting more and more complex...Therefore I'll write a list for the different brick versions.
I would like to continue this list with the 4 wide and 8 wide bricks, but I only own 4x6 and 4x12 (2356 and 4202). Therefore I would happily add these information, when I got them from someone else.
- 2x2 Brick
- without DesignID: thick sidewalls. (Interesting detail: there is a variable number in one the the inner anti studs)
- with DesignID 3003: like the version without DesignID OR with thin sidewalls + thickening
- 2x3 Brick
- without DesignID:thick sidewalls
- with DesignID 3002: thin sidewalls + thickening + reinforcements for each underside stud
- 2x4 Brick
- without DesignID: thick sidewalls OR thin sidewalls + thickening + all three underside studs have a 2.4 mm depth slot
- with DesignID 3001: thin sidewalls + thickening + reinforcement for the underside stud in brick center
- 2x6 Brick
- with DesignID 2456: thick sidewalls + reinforcements for the 2nd and 4th underside stud
- with DesignID 44237: thin sidewalls + thickening + reinforcements for the 2nd and 4th underside stud
- 2x8 Brick
- without DesignID: thick sidewalls + reinforcements for the 2nd, 4th and 6th underside stud
- with DesignID 3007: like the version without DesignID
- with DesignID 93888: thin sidewalls + thickening + reinforcements for the 2nd, 4th and 6th underside stud
- 2x10 Brick
- without DesignID: thick sidewalls + reinforcements for the 2nd, 4th, 6th and 8th underside stud
- with DesignID 3006: like the version without DesignID
- with DesignID 92538: thin sidewalls + thickening + reinforcements for the 2nd, 4th, 6th and 8th underside stud
