Full Version: List of models used?
Is there a quick way to list which models are being used in Datsville? I want to compare this with the contents of my working directory. That way I can find out which models *aren't* being used, which is what I really want to know.
If you are working under Windows MPDCenters new version (not yet released) can give that answer.
Are you interested in testing? Smile
Does it work for LDR models as well? Not just MPD models?
It works for models at all.
But you need to work under windows Smile
If you like to test it (it is not yet released) I am going to make it as a new release.
The steps you need to do is:
1) Open datsville.ldr with MPDCenter
2) Use the menu command - import unofficial files.
As all models are unofficial files in this context MPDCenter tries to import all files that are referenced and you get a windows asking for importing all that files. At this point you can copy the list to your text editor.
But please note that you should only work at present on a copy of your important data!!
Please let me know if you are interested. I am sure that MPDCenter will help you a lot in the work with datsville, but I am also sure that there are still errors in my code for MPDCenter.
Edit:
The list of files that MPDCenter tries to import is as follows if I use datsville_rev256:
layer_streets.ldr
layer_river.ldr
layer_traffic.ldr
block_001.ldr
block_002.ldr
block_003.ldr
block_004.ldr
block_005.ldr
block_006.ldr
block_007.ldr
block_008.ldr
block_009.ldr
block_010.ldr
block_011.ldr
block_012.ldr
block_013.ldr
block_014.ldr
block_015.ldr
block_016.ldr
block_017.ldr
block_018.ldr
block_019.ldr
block_020.ldr
block_021.ldr
block_022.ldr
block_023.ldr
block_024.ldr
block_025.ldr
snotroad_tripleonewaynocross.ldr
infrastructure_trashcan.ldr
infrastructure_signnoleftturn.ldr
infrastructure_lightdouble.ldr
snotroad_doublestriperightonly.ldr
infrastructure_streetlamppair.ldr
infrastructure_streetlampsingle.ldr
snotroad_doublestripenocross.ldr
snotroad_quaddotsnocross.ldr
infrastructure_signstopquad.ldr
infrastructure_lightquad.ldr
snotroad_doublestripecross.ldr
snotroad_doubleonewaydoublecross.ldr
snotroad_tripleblankcross_2.ldr
snotroad_tripleonewaycross_2.ldr
infrastructure_signnoentryboth.ldr
infrastructure_signnorightturn.ldr
infrastructure_signstopsingleboth.ldr
snotroad_tripleonewaycross_1.ldr
snotroad_doubleonewaynocross.ldr
snotroad_doubleonewaycross.ldr
infrastructure_signstopsingle.ldr
snotroad_tripleblanknocross.ldr
infrastructure_lighttriple.ldr
snotroad_doublestripeleftaheadonlydouble.ldr
snotroad_doublestriperightaheadonly.ldr
infrastructure_busstop.ldr
infrastructure_roadbridge.ldr
snotroad_culdesac.ldr
snotroad_tripleblankcross_1.ldr
snotroad_curveonewaynocross.ldr
snotroad_curveblanknocross.ldr
snotroad_curvestripenocross.ldr
infrastructure_railsection.ldr
infrastructure_railcrossing.ldr
vehicle_048_bluedigger.mpd
pedestrian_038_blueworker.ldr
vehicle_049_blueloader.mpd
vehicle_050_bluecargo.ldr
vehicle_052_bluedozer.ldr
vehicle_001_yellowbulldozer.mpd
vehicle_002_yellowheavyequipmentcarrier.ldr
vehicle_003_redfireboat.ldr
vehicle_004_yellowtractorshovel.ldr
vehicle_005_yellowasphaltspreader.ldr
vehicle_006_yellowrockbreaker.ldr
vehicle_007_whitepolicecar.ldr
vehicle_036_whitepolicevan.ldr
vehicle_037_whitepolicevan02.ldr
vehicle_008_redfirecar.ldr
vehicle_009_graycoupe.ldr
vehicle_010_graystationwagon.ldr
vehicle_011_graybmwsedan.ldr
vehicle_012_blueandwhitebus.ldr
vehicle_013_yellowroundmailvan.ldr
pedestrian_026_castleguard.ldr
vehicle_014_blacksemitruck.mpd
vehicle_015_whitesportscar.ldr
vehicle_016_redpickuptruck.ldr
vehicle_017_graysemitruck.mpd
vehicle_018_graypolicemotorcycle.ldr
vehicle_019_oteconn1.ldr
vehicle_020_redconvertiblecar.ldr
pedestrian_005_womanredhairwalking.ldr
vehicle_021_blueandwhitedeliverytruck.ldr
vehicle_022_whiteconvertiblecar.ldr
vehicle_023_bluemotorcycleandrider.ldr
vehicle_024_blackmotorcycleandredrider.ldr
vehicle_025_redmotorcycleandwhiterider.ldr
vehicle_026_bluecoupe.ldr
vehicle_027_grayconvertible.ldr
vehicle_028_yellowtraincarwithblacktrailer.ldr
vehicle_029_blacklimousine.ldr
pedestrian_001_mustachewalking.ldr
pedestrian_002_suitblackhat.ldr
pedestrian_003_blueoverallsandhat.ldr
pedestrian_004_sleevelesswaving.ldr
pedestrian_006_womanbrownhairminiskirt.ldr
pedestrian_007_manprofessortophat.ldr
pedestrian_008_manpoliceleatherjacket.ldr
vehicle_043_towercrane.mpd
vehicle_045_redpassengertrain.mpd
building_001_jessimanmemorial.mpd
building_002_townhall.mpd
building_003_eastwickechapel.ldr
building_043_datsvillememorial.ldr
infrastructure_bigtree01.ldr
building_007_firecompany.ldr
building_023_missionstylehouse.ldr
building_005_houseporch.ldr
building_011_bramshome.ldr
building_010_johnshouse.ldr
building_021_houseporchyard.mpd
building_013_safehouse.ldr
building_004_bramlcottage.ldr
building_014_watertower.ldr
infrastructure_bigtree03.ldr
building_015_parisianshop.ldr
building_042_glassstore.ldr
building_012_triplex.ldr
infrastructure_bigtree04.ldr
building_006_casaverde.ldr
building_050_smallpark02.mpd
building_066_horvathwhitehouse.mpd
building_016_postoffice.ldr
building_017_nationalbank.ldr
building_019_cricketground.mpd
building_018_datsvillecollege.ldr
building_041_collegelawn.ldr
building_051_highschool.mpd
building_022_houseonahill.mpd
infrastructure_ljphill1.ldr
infrastructure_ljphill2.ldr
building_058_bundenogkanden.mpd
building_040_lookouttower.ldr
building_020_baitshop.ldr
building_060_icecreamparlor.mpd
building_055_traveloffice.mpd
building_053_animalexhibit.ldr
building_052_newspaperoffice.mpd
building_009_miningfacility.mpd
infrastructure_ltehill3.ldr
building_008_roundpolicebuilding.ldr
building_044_amateurradioclubbuilding.ldr
building_069_amateurradioclubantenna.mpd
vehicle_019_weirdportalonwheels.mpd
building_024_andershouse.ldr
building_054_blueranchstyle.ldr
building_025_greenroofhouse.ldr
building_061_horvathsalmonhouse.mpd
building_049_smallpark01.mpd
building_065_horvathbluehouse.mpd
building_029_movietheater.ldr
building_072_yelhouse.ldr
building_067_habidome.mpd
building_028_sidewalkblocksnogarage.ldr
building_026_toresparentshouse.ldr
building_030_policehq.ldr
building_027_thomashouse.ldr
building_032_grocerystore.ldr
infrastructure_phonebooth.ldr
building_059_restaraunt.mpd
building_046_smallgarage.mpd
building_031_carriagehouse.mpd
building_033_telephoneexchange.ldr
infrastructure_celltower.mpd
building_035_petrolstation.mpd
building_034_blueapartments.mpd
building_037_trainstation.ldr
building_073_radiotower.ldr
building_038_hospital.ldr
building_039_tanmosque.mpd
building_045_yellowcastle.mpd
building_057_castletavern.ldr
infrastructure_bikepathstraight.ldr
building_071_redbarn.mpd
building_070_bikerack.mpd
building_064_baseballpark.mpd
building_063_officebuildingsmall.mpd
building_068_warehousesmall.mpd
building_036_shoppingcenter.mpd
building_048_pizzatakeout.mpd
infrastructure_trafficsignal.ldr
infrastructure_streetlamp_2.ldr
snotroad_doublestriperailxing.ldr
vehicle_030_redfiretruck01.ldr
vehicle_031_redfiretruck02ladder.ldr
vehicle_032_redfiretruck03.ldr
vehicle_033_redfiretruck04suv.ldr
vehicle_034_redfiretruck05.ldr
vehicle_035_redfiretruck06.ldr
pedestrian_013_manblacksuitdriving.ldr
pedestrian_014_mandarkskingraysuitdriving.ldr
pedestrian_015_mangreengraysuitmustache.ldr
pedestrian_012_manexplorerbinoculars.ldr
pedestrian_009_manblueoverallsmustache.ldr
pedestrian_010_manblueoverallssunglasses.ldr
pedestrian_025_womanblondehairredsleeves.mpd
pedestrian_019_manblondehairwhiteshirt.ldr
vehicle_040_whiteambulance.ldr
pedestrian_016_manblueoverallsblackhatsitting.ldr
pedestrian_017_manredspacelogosunglassessitting.ldr
dx901.dat
dx900.dat
dx901.dat
dx900.dat
vehicle_023_vtemc1.ldr
dx901.dat
dx900.dat
dx901.dat
dx900.dat
vehicle_028_rjjtfc1.ldr
vehicle_041_graytractortrailer.ldr
3024l46.dat
pedestrian_011_manmayortophat.ldr
infrastructure_bigtree02.ldr
infrastructure_flowercomplete.ldr
pedestrian_037_bluefiguresit1.ldr
pedestrian_036_bluefiguresit2.ldr
pedestrian_042_medic_1.ldr
pedestrian_041_fman_stand.ldr
pedestrian_040_fman_sit_2.ldr
pedestrian_039_fman_sit_1.ldr
pedestrian_043_medic_2.ldr
vehicle_038_redpickuptruck02.ldr
pedestrian_020_manbluestripeswhitecapsunglasses.ldr
vehicle_039_yellowshelltankertruck.ldr
pedestrian_021_manredoverallsredcap.ldr
pedestrian_022_manshelllogoredcap.ldr
2536c01.ldr
infrastructure_streetlamp_1.ldr
pedestrian_023_manfiremanredcapdriving.ldr
pedestrian_024_manshelllogoredcapsitting.ldr
vehicle_042_yellowtankertrailer.ldr
Yes, I would like to try the program. Thanks!
You can now download the new BETA!! version from MPDCenter website. Please ensure that you download the BETA and not the current released version.
Please remember, it is a BETA version and I know some issues that needs to be solved, for example, if you "import unofficial files" and then hit in the upcoming windows the cancel button, MPDCenter crashes.
But just these things can only be found by using the application. I try to answer and correct code as fast as possible to assist you in your experience with MPDCenter.
Please leave all comments, questions etc. as answer to this thread, so all MPDCenter relevant informations are at one place. Thank you.
Edit:
Just uploaded a new BETA that does not crash anymore if you cancel file import.
