wow.
this will be the reason for me to try Blender the first time after long years of POVRay.
thank you for sharing this!
Wow! glad you choose one of my most complex "babies" for this image
The EV3 would have looked good in this color!
Too bad about the lack of MPD support. Most of my models are MPD.
You can use MPDCenter to combine what you need into one single LDR file!
But there is no possibility to split that file later again into its components.
So for viewing purpose you can have what you like.
You can always use a tool like
MPDCenter to create a non-MPD version of your model so that you can then use this importer.
Doesn't work in Blender v2.70a
When I enable it addons window there is immediately yellov exclamation in triangle beside it and when trying to import my .ldr it says: "File not imported (FileNotFoundError)"
EDIT:
it does not work only for some .ldr's, complaining mostly that it cannot find some .dat files although there are there in "p" directory of LDraw...strange.
+also notices some strange artefacts on "computer" slope bricks where the texture is not OK, it is striked somehow with blackish strikes or "mish-mashed" with black something (hard to name it)
I am finally testing the importer. It seems to work well, except for transparent colors not being transparent. I tried rendering both in Cycles and Yafaray, and the transparent colors in my model are opaque. Is there a way to fix this? Thanks.
just saw this - must have overlooked this for many years ?
many thanks, and keep up the good work with the Blender importer!
Okay, I tried importing a very old version of Datsville using this addon. I started on 3:45 am Sunday, and it is still not done on 10:15 pm Monday.
So I give up.
Maybe you should try with less data.
(2018-03-20, 8:23)Jarema Wrote: [ -> ]Maybe you should try with less data.
I already described doing so.
