My try to create this model.
Later I will add stickers, and maybe try to create curtains. Thanks to Max Richter for creating rubber belt.
Very nice, thank you. Going to have to figure out a way to add some drive-train to the model now.
Great work. But there are some faults.
The red Arch must be raised (use: 92950.dat) and the front hoses are going through a 1x2 tile.
Do you have the real model as well?
Max
Thank you. I know that there are some faults) I fix most of them. Now I am drawing stickers and then will post fixed model.
I fix some bugs I have found. But I don't know how to fix hoses. I tried to redo it with LSynth, but not good. I put 2 LSynth elements at the beginning, and 2 at the end. And they cross tiles. I tried to put some more Lsynth elements in center of hose, but it looks to unnatural. Please if you have time describe me how to do it. And if you want, you can do everything with this model)))) Even ruin it by deleting part by part)))
I don't have this set yet, because it will appear in place where I live much later(
I have the part and took some measures. Here is what I found despite it has been a bit distorted over the time
(2020-05-18, 15:36)Vincent Messenet Wrote: [ -> ]I have the part and took some measures. Here is what I found despite it has been a bit distorted over the time
Awesome! many thanks.
(2020-05-17, 10:38)Willy Tschager Wrote: [ -> ]Would a good soul please OMRize this model?
I can OMRize this file if you want. Add stepping, submodel and update flexible parts.
MG
(2020-05-18, 18:07)Marc Giraudet Wrote: [ -> ]I can OMRize this file if you want. Add stepping, submodel and update flexible parts.
MG
Looking at the current file I'd say that submodeling is key.
(2020-05-18, 21:07)Willy Tschager Wrote: [ -> ]Looking at the current file I'd say that submodeling is key.
attachment=5261]
attachment=5260]
File OMR compliant.
Known errors : Missing stickers. And 94318.
1x plate 1x1 white, missmatch between inventory and instructions (used 6146249/6205513). Total 35 not 36.
94318 added but not embedded. Stickers not added, I let you finish your project.
File with 2 versions (opened and closed roof).
attachment=5263]
attachment=5262]
(2020-05-22, 16:28)Marc Giraudet Wrote: [ -> ]94318 added but not embedded. Stickers not added, I let you finish your project.
Only a note for myself, that I don't forget this thread.
Any idea when the model is finished?
(2020-08-30, 15:21)Johann Eisner Wrote: [ -> ]Only a note for myself, that I don't forget this thread.
attachment=6284]
I think this file is complete, with new part and all stickers. Some improvements done (windscreen angle, roof bars).
