I installed the All-In-One-Installer and it also installed LDView's plugin that shows thumbnails in Windows Explorer. How do I turn just that bit off without uninstalling everything? Thanks.
You'll have to unregister the LDViewThumbs.dll in the Command Prompt:
regsvr32 /u LDViewThumbs.dll
Bye, w.
I got the message
LoadLibrary("LDViewThumbs.dll") failed- The specified module could not be found.
I am running Windows XP SP3.
Dis you set the file path of the dll in quotes?
I believe that Willy's command line will only work if run from within the directory where LDView is installed (C:\Program Files\LDView by default).
Well also this:
regsvr32 /u "C:\Program Files\LDraw\LDView\LDViewThumbs.dll"
is supposed to work. If not I have to recode the uninstaller :-(
Yes, Willy, including the full path to LDViewThumbs.dll in the regsvr command line will also work.
