I am building 10220 set. Please help me to create belt in engine. I send file with 2 parts where I need belt. I try to do with LSynth, but it took only 1 part and create belt around it.
Hi Stan,
I know this problem very well. So here is a first test-version, created in within 10 minutes. It doesn't look really nice, so I will do a good version today in the evening or monday morning. I hope this is ok for you.
Max
Thank you. I see this preversion. I hope you will improve it. I'm not hurry))
Hi Stan,
I think, that's it. Is it OK for you or should I change something?
Btw. 10220 is a really nice model. I'd build it yesterday. While building it, I had the same idea to made it with CAD
But I've no idea how do implement the Curtain and the Orange Cloth for the roof...
So have fun while building!
Max
Hi Stan,
Btw 10220 is a really nice model. I'd build it yesterday and while building, I had the same idea to made it with CAD
Max
Thank you very much. It looks great.
I'm sitting in a train, so I have some minutes to explain how I did it.
First of all I had created a new line in the LSynth.ini (at the end of the "hose-section")
0 FILE RUBBER_BAND_HOSE.ldr
0 RUBBER_BAND_HOSE SYNTHESIS DEFINITION
0 Name: RUBBER_BAND_HOSE.ldr
0 Unofficial Model
0 SYNTH BEGIN DEFINE RUBBER_BAND_HOSE HOSE STRETCH 2 40 0
1 0 0 0 0 2 0 0 0 1 0 0 0 2 LS11.dat
0 SYNTH END
With this code is it possible to make a rubber by using the the "nomal" Constraints e.g. ' LSynth Constraint Part - Type 4 - "String" ' LS04.dat
The rest should be clear. Attention: the last Constraint must be exactly on the position of the first one, otherwise it won't be a band
One last thing: please change the color to: 324 rubber_red. I used only: 4 red.
Max
One more question to LSynth masters)
Is it possible make this string around Hose Reel more round. I use as example LSynth examples, But there are such problems. It is look like square.
You can get a bit better result by reducing string stiffness. To do that you need to change string definition in lsynth.mpd (in lsynth/bin folder): change
0 FILE STRING_HOSE.ldr
0 STRING_HOSE SYNTHESIS DEFINITION
0 Name: STRING_HOSE.ldr
0 Author: Kevin L. Clague
0 Unofficial Model
0 SYNTH BEGIN DEFINE STRING_HOSE HOSE FIXED 2 [b][color=#FF0000]10[/color][/b] 0
1 0 0 0 2 1 0 0 0 0 1 0 -1 0 LS60.dat
1 2 0 0 2 1 0 0 0 0 1 0 -1 0 LS60.dat
0 SYNTH END
to
0 Unofficial Model
0 SYNTH BEGIN DEFINE STRING_HOSE HOSE FIXED 2 [b][color=#FF0000]5[/color][/b] 0
0 SYNTH END
Also the position of constraints could be a bit improved (see attached)
Are you modeling the Maersk Container Ship now?
An other way is to use more constraints. For example 8 per round.
But Lsynth can handle a limited number of constraints only. I'd never checked the exactly number. But I know, if there are too much, the program crashes down. Is here anybody who know this number?
Martin
Actually I’m creating a string in MLCad/LSynth. Here is a WIP-Screenshot:
I already manipulated the lsynth.mpd-file as described by Phillippe. But there was more or less no improvement.
As the initial poste was from 2011 I wonder if meanwhile there is a function in LSynth or maybe a better solution which automatically helps to make a string hose less edged? I am thinking of a spline curve, or radius adjustment or anything similar.
The only technique to get the string somehow more flowing/smooth I am actually aware of is to insert tons of constraints. Is there any easier way?
Thanks
Roland
Can you draw a line how it shoud look, i.e. how it is intended to look? ... and the dat fiel with the constraints
Thanks
Thanks for your fast response.
Here is the dat-file
The string is dedicated as snowspeeder rope:
I have highlighted the parts which you will find in the dat-file in yellow:
You made me curious! Do you own some magic tools?
regards
roland
I finished the project! Approximately 90 constraints were required for getting a satisfying result:
High Resoultion Image
However: I am still interested in smarter solutions ....
Roland D. Wrote:Approximately 90 constraints
Phew :p
Quote:However: I am still interested in smarter solutions ....
Could you share your initial attempt with few constraints? I don't quite understand why increasing stiffness doesn't work well here.
Phillipe,
reading your advice from 2011 my brain was somehow disabled. I did exactly what you proposed: I decreased the stiffness value from 10 to 5.
According to your new poste I switched on my brain again: Increasing the stiffness value to 100 leads to an excellent and elegant result by only having 12 constraints!!!!!
Thanks for your thought-provoking impulse!
Yeah, sometimes neurons are useful ;D
