Full Version: Brickarms Parts?
Pages: 1 2
Not sure what you mean by hole but there is no hole in the tube/bar. The whole thing seems to be the same height as the tile if that's what you're talking about.
OK, sorry, indeed it's obvious from your photos, it's a 3.2mm diameter bar with no hole!
Here they are... If you have good relations with Brickarms, maybe you can propose them to put these files on their website?
Oh wonderful! Thank you SO much! Let me know if I can pay you for your time. I really appreciate it.
I do have a good relationship with Will and I actually asked him first if he happened to have these parts for Ldraw. I know Dan Siskind does instructions for his kits and would probably be able to make use of these.
I'm not sure if you're aware or not, but the parts show up under the "brick" category, but I saw that you listed the category as "minifig accessory". This makes absolutely no difference to me, but I just thought I'd let you know if you weren't aware.
Quote:Oh wonderful! Thank you SO much! Let me know if I can pay you for your time. I really appreciate it.
Wink Lets say I was paid in advance watching your great mocs on the net!
Quote:I'm not sure if you're aware or not, but the parts show up under the "brick" category, but I saw that you listed the category as "minifig accessory". This makes absolutely no difference to me, but I just thought I'd let you know if you weren't aware.
Ah - yes, MLCad is not utterly clever in parts tree creation, since the name begins with "Brickarms" it stores them in bricks section (and it doesn't manage the category keyword, so the "minifig accessory" gets ignored)... If someone could coin a more functionnal naming...???
My suggestion would be "Clip Double" and "Clip on Bar End"
Hey there - I've used LDraw for years, but only now registered, just so I could get those Brickarms parts you created for Tyler. But for some reason I can't download the files - I'm being redirected to a page that says I'm not logged in (user name in top left corner changes to "Guest"), and when I try to log in with my newly created account it tells me that the "authorization code failed" - even though there was no authorization code required, just my user name and password. Can you help?
EDIT: Never mind! It works now. Probably only a matter of giving the account enough time to be fully activated.
Keep up the good work! I prefer LDraw and the parts you all make to any other digital building tool.
Best regards
Are J Heiseldal (L@go)
Pages: 1 2
