Creator - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Official Models (https://forums.ldraw.org/forum-17.html) +--- Thread: Creator (/thread-7939.html) Pages:
1
2
30572 - Race Car [Creator 2019] - Marc Belanger - 2019-12-07 File is OMR compliant Done with LDCad 1.6c Rendered with Studio 2.0 RE: Creator 31048 - Stefan Frenz - 2019-12-08 31048 Lakeside Lodge (A model of 3in1) Should be OMR compliant. Done with LDCad 1.6c. Questions / known issues: - Face of MiniFig has wrong pattern (could not find correct one in library). I already looked at Rebrickable and BrickLink without success - what is the best way to find the correct one? - Shirt of MiniFig seems to have pattern of 973pdd like in 31038 (officially downloadable OMR), but color of stripes is red. Are my eyes getting bad, or should the stripes be red in 31038, too? I added the 973pdd in the mpd file with changed color - is this the way it should be done? - BrickLink and Rebrickable show "98313" for the moose's antlers, but LDraw-item seems to be 76116. - no B models. Thanks for any suggestion. Edit: removed old version of mpd, fixed one is below. RE: Creator 31048 - Philippe Hurbain - 2019-12-08 (2019-12-08, 12:58)Stefan Frenz Wrote: - Face of MiniFig has wrong pattern (could not find correct one in library). I already looked at Rebrickable and BrickLink without success - what is the best way to find the correct one?The correct head is 3626cp8i.dat. I found it by looking at Bricklink description and looked for "lopsided" in LDraw parts. We now try to include Bricklink reference as keyword, but this older part doesn't include it. Quote:- Shirt of MiniFig seems to have pattern of 973pdd like in 31038 (officially downloadable OMR), but color of stripes is red. Are my eyes getting bad, or should the stripes be red in 31038, too? I added the 973pdd in the mpd file with changed color - is this the way it should be done?Printed part color is always difficult to assert, especially on dark colors (paint is partially transparent). 973pdd uses brown, which seems to visually match most images I could see on the web (eg. https://youtu.be/VMRLd7V4CoI?t=29 ). Notable exception is LEGO image https://www.lego.com/service/bricks/5/2/6155272 but it's computer generated, so no real life transparency Quote:- BrickLink and Rebrickable show "98313" for the moose's antlers, but LDraw-item seems to be 76116.Now on PT: https://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/98313.dat. Note that Brickset (whose data comes from LEGO) uses 76116 reference. I have also sent an updated 76116 to part admin. RE: Creator 31048 - Stefan Frenz - 2019-12-08 Again thank you very much, Philippe! Now fixed head and reverted shirt to 973pdd with brown stripes (still not sure even by looking at the real part). Edit: fixed subfile headers. 31088 - Deep Sea Creatures [Creator 3-in-1 2019] - Marc Belanger - 2019-12-12 Shark Squid Angler Fish Extra Building Instructions: Whale All files are OMR compliant Done with LDCad 1.6c Rendered with Studio 2.0 RE: Creator 31025 - Stefan Frenz - 2019-12-22 Fixed tyre color: Black => Rubber Black. At the moment, this model is not yet in the OMR database. Is it correct to skip the HISTORY-tag for this change or should it be included even if it is not official yet? RE: Creator 31025 - Orion Pobursky - 2019-12-22 (2019-12-22, 16:07)Stefan Frenz Wrote: Fixed tyre color: Black => Rubber Black. Don't worry about it. HISTORY tags are optional for the OMR and the standards a far looser than the PT. RE: Creator 31025 - Stefan Frenz - 2019-12-30 Fixed 1x1 Clip color Black => Dark Bluish Gray, fixed main ldr sub-filename to comply with OMR rules (hopefully, and I hope it is ok to leave the "-1" for this model to not-change the filename of an already uploaded file). RE: Creator 31025 - Stefan Frenz - 2019-12-30 (2019-12-06, 13:13)Stefan Frenz Wrote: 31025 Mountain Hut (A model of 3in1)Attached is first 31025 Mountain Hut B-model "Small Lodge". Done with LDCad 1.6c, file should be OMR compliant (I hope it is ok to leave the "-1" for this model to have the same set-number as the already uploaded file for the A-model). Known issues: none. RE: Creator 31025 - Stefan Frenz - 2020-01-04 (2019-12-06, 13:13)Stefan Frenz Wrote: B models not included.Attached is second 31025 Mountain Hut B-model "Mountaintop Lookout". Done with LDCad 1.6c, file should be OMR compliant (I hope it is ok to leave the "-1" for this model to have the same set-number as the already uploaded file for the A-model). Known issues: none. RE: Creator 31048 - Stefan Frenz - 2020-01-07 31048 Lakeside Lodge - Observatory (first B model of 3in1) File should be OMR compliant (I hope that it's ok to keep the "-1" to have the number of the A model). Done with LDCad 1.6c, known issues: none. RE: Creator 31048 - Stefan Frenz - 2020-01-07 31048 Lakeside Lodge - Small Cabin (second B model of 3in1) File should be OMR compliant (I hope that it's ok to keep the "-1" to have the number of the A model). Done with LDCad 1.6c, known issues: none. RE: Creator - 4883 - Gear Grinders - Marc Giraudet - 2020-01-21 4883 - Gear Grinders 6 Quick Build Models 4883 - Quick Build Car 1.mpd (Size: 3.57 KB / Downloads: 6) 4883 - Quick Build Car 2.mpd (Size: 3.46 KB / Downloads: 6) 4883 - Quick Build Car 3.mpd (Size: 2.18 KB / Downloads: 6) 4883 - Quick Build Car 4.mpd (Size: 2.96 KB / Downloads: 6) 4883 - Quick Build Car 5.mpd (Size: 3.67 KB / Downloads: 7) 4883 - Quick Build Quad.mpd (Size: 3.08 KB / Downloads: 6) Files OMR compliant Known error : None Made with LDCad (my good resolution of this year !) RE: Creator - 4883 - Gear Grinders - Marc Giraudet - 2020-01-21 (2020-01-21, 21:03)Marc Giraudet Wrote: 4883 - Gear Grinders RE: Creator - 4883 - Gear Grinders - Marc Giraudet - 2020-01-21 4883 - Gear Grinders 5 Advanced Models 4883 - Advanced Build 4WD.mpd (Size: 7.44 KB / Downloads: 6) 4883 - Advanced Build Forklift.mpd (Size: 6.11 KB / Downloads: 6) 4883 - Advanced Build Formula 1.mpd (Size: 5.68 KB / Downloads: 6) 4883 - Advanced Build Truck and Trailer.mpd (Size: 11.43 KB / Downloads: 7) 4883 - Advanced Build Truck.mpd (Size: 7.08 KB / Downloads: 6) Files OMR compliant Known error : None Made with LDCad RE: Creator - 4883 - Gear Grinders - Philippe Hurbain - 2020-01-22 17 models for a 273 pcs set... wow! RE: Creator 4954 - 4959 - 4996 Houses - Marc Giraudet - 2020-01-24 4954 - Models 2 and 3 4954 - Houses with Truck.mpd (Size: 42.76 KB / Downloads: 13) 4954 - School.mpd (Size: 41.74 KB / Downloads: 10) [size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size] RE: Creator 4954 - 4956 - 4996 Houses - Marc Giraudet - 2020-01-24 4954 - Model Town House.mpd (Size: 55.9 KB / Downloads: 8) 4954 New file with updated windcreen car color (transblack) and other minor correction RE: Creator 4954 - 4956 - 4996 Houses - Marc Giraudet - 2020-01-25 4956 - Models 2 and 3 4956 - House with Arch.mpd (Size: 29.89 KB / Downloads: 12) 4956 - Small Houses.mpd (Size: 24.62 KB / Downloads: 9) And model 1 with minor correction (use new door part 47899c01 / 73194c01) 4956 - House.mpd (Size: 30.15 KB / Downloads: 9) RE: Creator 4954 - 4959 - 4996 Houses - Marc Giraudet - 2020-01-27 4996 - Models 2 and 3 4996 - Building.mpd (Size: 19.58 KB / Downloads: 8) 4996 - Restaurant.mpd (Size: 22.63 KB / Downloads: 9) [size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studio[/font][/size] RE: Creator 4896 - Roaring Roadsters - Marc Giraudet - 2020-01-30 4896 models 2 and 3 4896 - Dragster.mpd (Size: 15.88 KB / Downloads: 6) 4896 - 4WD.mpd (Size: 34.82 KB / Downloads: 5) [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size][/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size][/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studio[/font][/size][/font][/size] RE: Creator 4896 - Roaring Roadsters - Marc Giraudet - 2020-01-31 (2019-11-24, 20:39)Marc Giraudet Wrote: Set 4896 - Roaring Roadsters - Roadster 4896 - Roaring Roadsters - Roadster.mpd (Size: 46.99 KB / Downloads: 3) File with minor correction. Part and color updated. RE: Creator - 4404 - Land Busters - Marc Giraudet - 2020-02-07 4404 - Land Busters 3 models 4404 - Land Busters.ldr (Size: 77.5 KB / Downloads: 5) 4404 - Bike.mpd (Size: 19.04 KB / Downloads: 4) 4404 - Dragster.mpd (Size: 29.68 KB / Downloads: 5) [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size][/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size][/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studi[/font][/size][/font][/size][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]o[/font][/size][/font][/size] RE: Creator - 31031 - Rainforest Animals - Marc Giraudet - 2020-02-09 31031 - Rainforest Animals 31031 - Rainforest Animals.mpd (Size: 13.72 KB / Downloads: 5) 31031 - Fish.mpd (Size: 5.51 KB / Downloads: 4) 31031 - Chameleon.mpd (Size: 8.55 KB / Downloads: 6) [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size][/font][/size][/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size][/font][/size][/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studi[/font][/size][/font][/size][/font][/size][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]o[/font][/size][/font][/size][/font][/size] RE: Creator - 31038 - Changing Seasons - Marc Giraudet - 2020-02-09 31038 - Changing Seasons 31038 - Changing Seasons.mpd (Size: 31.8 KB / Downloads: 6) 31038 - Winter.mpd (Size: 21.83 KB / Downloads: 8) 31038 - Automn.mpd (Size: 22 KB / Downloads: 6) [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Files OMR compliant[/font][/size][/font][/size][/font][/size][/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Known error : None[/font][/size][/font][/size][/font][/size][/font][/size] [size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]Made with LDCad, rendered with Studi[/font][/size][/font][/size][/font][/size][/font][/size][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif][size=small][font=Tahoma,Verdana,Arial,Sans-Serif]o[/font][/size][/font][/size][/font][/size][/font][/size] RE: Creator - 30472 - Parrot polybag - Marc Giraudet - 2020-03-10 30472 - Parrot polybag 30472 - Parrot polybag.mpd (Size: 3.37 KB / Downloads: 3) File OMR compliant Known error : None Creator 31009 Small Cottage - Stefan Frenz - 2020-03-14 Main model of 31009: Small Cottage Done with LDCad 1.6c (Linux64). File should be OMR compliant. Known issues: none. RE: Creator 31009 B-Models - Stefan Frenz - 2020-03-15 B-Models of 31009: Skater's House and Windmill. Done with LDCad 1.6c (Linux64). Files should be OMR compliant. Known issues: none. 31049 - Twin Spin Helicopter [Creator 3-in-1 2016] - Marc Belanger - 2020-05-04 Twin Spin Helicopter Snowmobile Single-Engine Airplane All files are OMR compliant Done with LDCad 1.6c Rendered with Studio 2.0 RE: Creator - 4939 - Cool Cars - Marc Giraudet - 2021-04-03 4939 - Cool Cars 4939 - Cool Cars - Car.mpd (Size: 12.59 KB / Downloads: 4) File OMR compliant Known error : None RE: Creator - 4939 - Cool Cars - Marc Giraudet - 2021-04-03 4939 - Cool Cars - Formula 1.mpd (Size: 8.48 KB / Downloads: 2) File OMR compliant Known error : None RE: Creator - 4939 - Cool Cars - Marc Giraudet - 2021-04-03 4939 - Cool Cars - Truck.mpd (Size: 11.75 KB / Downloads: 5) File OMR compliant Known error : None RE: Creator - 4953 - Fast Flyers - Marc Giraudet - 2021-04-03 4953 - Fast Flyers 4953 - Fast Flyers- Plane.mpd (Size: 18.34 KB / Downloads: 3) File OMR compliant Known error : None RE: Creator - 4953 - Fast Flyers - Marc Giraudet - 2021-04-03 4953 - Fast Flyers - Helicopter.mpd (Size: 8.32 KB / Downloads: 4) File OMR compliant Known error : None RE: Creator - 4953 - Fast Flyers - Marc Giraudet - 2021-04-03 4953 - Fast Flyers - Overcraft.mpd (Size: 13.38 KB / Downloads: 3) File OMR compliant Known error : None RE: Creator - 4955 - Big Rig - Marc Giraudet - 2021-04-18 4955 - Big Rig - Truck 4955 - Big Rig - Truck.mpd (Size: 32.77 KB / Downloads: 6) File OMR compliant Known error : None RE: Creator - 4955 - Big Rig - Marc Giraudet - 2021-04-18 4955 - Big Rig - Cart 4955 - Big Rig - Cart.mpd (Size: 19.91 KB / Downloads: 4) File OMR compliant Known error : None RE: Creator - 4955 - Big Rig - Marc Giraudet - 2021-04-18 4955 - Big Rig - Car 4955 - Big Rig - Car.mpd (Size: 23.05 KB / Downloads: 4) File OMR compliant Known error : None RE: Creator - 7347 - Highway Pickup - Marc Giraudet - 2021-04-25 7347 - Highway Pickup 7347 - Highway Pickup.mpd (Size: 55.26 KB / Downloads: 4) File OMR compliant Known error : None RE: Creator - 7347 - Highway Pickup - Marc Giraudet - 2021-04-25 7347 - Highway Pickup - Truck 7347 - Highway Pickup - Truck.mpd (Size: 40.68 KB / Downloads: 3) File OMR compliant Known error : None RE: Creator - 7347 - Highway Pickup - Marc Giraudet - 2021-04-25 7347 - Highway Pickup - Car 7347 - Highway Pickup - Car.mpd (Size: 22.14 KB / Downloads: 4) File OMR compliant Known error : None 31070 - Turbo Track Racer - Stefan Frenz - 2021-05-19 31070 - Turbo Track Racer (2017) Done with LDCad 1.6d (Linux64) Should be OMR compliant. Known errors: none. RE: Creator - Vincent Messenet - 2022-09-02 40469 - Tuk Tuk 40469 - Tuk Tuk.png (Size: 193.26 KB / Downloads: 199) OMR compliant Known errors: None RE: Creator - N. W. Perry - 2022-10-11 May I suggest/request that this thread be split by year as well? The Creator theme has been around a long time now… RE: Creator - Orion Pobursky - 2022-10-11 I agree. Thread Locked. Please post new model under Creator <year> |
