LDPatternCreator - Release 1.4.2 - Printable Version
+--- Thread: LDPatternCreator - Release 1.4.2 (/thread-6188.html)
LDPatternCreator - Release 1.4.2 - Nils Schmidt - 2012-09-10
Hey,
Here is the "answer to the Ultimate Question of Life, the Universe, and Everything": LPC 1.4.2 Wink
Please uninstall older versions of this software before installing a new version.
Your configuration won't be deleted if you have already version greater than 1.3.1 installed on your machine.
Change log:
New features:
  • You can deselect objects with the selection rectangle while pressing CTRL.
  • You can copy+paste the transformation matrices or vertex coordinates with 1 click.
  • You can toggle the visibility of the BG image (with Ctrl+B).
  • You can use a shortkey to dis-/enable the grid (Ctrl+G) / axis label (Ctrl+L).
  • The previous mode will be restored after closing the preview.
  • You can use a recent file list.
  • The French language file is improved.
Fixed bugs from 1.4.1 and older:
  • The file loader crashes because of side-effects from 1.3.8.
  • Zoom with +/​- does not work in preview mode.
  • The program crashes when a single group was created, deleted and saved.
  • Other minor bugs.
(see full list of tickets for 1.4.2)
I included a short readme.htm in the installation directory.
Cheers & Leg Godt
Nils
Re: LDPatternCreator - Release 1.4.2 - Philippe Hurbain - 2012-09-10
Looks like I have to do some patterns...
Re: LDPatternCreator - Release 1.4.2 - Willy Tschager - 2012-09-10
Wow - it's all there! The fine thing about LDPC is that it's almost a substitute for Christmas. You express a wish which gets fulfilled in short or no time. Thank you so much Nils.
