LPub Background Picture issue - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Help (https://forums.ldraw.org/forum-13.html) +--- Thread: LPub Background Picture issue (/thread-21896.html) |
LPub Background Picture issue - Steve - 2016-11-06 Hi, For some time i've tried to work out why in LPub, I cannot use the option under: Configuration - Page Setup - Background - Picture. I select an image from my pictures folder but it either hangs the system or greys out the page entirely. Is there a format / size that the picture needs to comply with? I am using Windows 7 Home. Everything else works well, I can add borders etc, I am using LPub 4.0.0.11. Any help would be much appreciated. Kindest regards Steve RE: LPub Background Picture issue - Jaco van der Molen - 2016-11-08 (2016-11-06, 1:36)Steve Wrote: Hi, Hi Steve, I do not recall exactly, but I think that function is broken in LPub 4.0.0.11. Neither does it support all image formats. What do you uses? PNG, JPG, BMP? Furthermore I'd advice you to take a look at LPub3D. It has many more features and is constantly under development. LPub 4.0.0.11 is no longer updated. Jaco |
