[LDPartEditor] 0.8.23 Beta Released (Context menus / LDU->stud / Async header check) - Printable Version
+--- Thread: [LDPartEditor] 0.8.23 Beta Released (Context menus / LDU->stud / Async header check) (/thread-21735.html)
[LDPartEditor] 0.8.23 Beta Released (Context menus / LDU->stud / Async header check) - Nils Schmidt - 2016-08-29
Hey,
release 0.8.23 comes with 6 bug fixes and 8 enhancements.
...I am going to write more content for the wiki/manual now.
[Image: imgDuke2.png]
Changelog:
(8 new features and 6 bug fixes)
  • ...convert a unit to stud (20 LDU = 1.0 stud, rounded to one decimal place).
  • ...access all context menu features from somewhere else, too.
  • ...use the "Expand Area" buttons to "toggle" the divider position between the text and the 3d editor.
  • ...use more dynamic context menus.
  • ...benefit from the fact that there are bigger previews for the primitive area by default.
  • ...benefit from the fact that "Text on the right / 3D on the left" is now the default window setting.
  • ...see the stud logos on the upper left view when you use the PartReview tool.
  • ...benefit from an asynchronous file header check (performance improvement / preparations for more validation features).
  1. Deleting all text lines from a file with the text editor could sometimes freeze LDPE.
  2. The PartReview tool did not close+reload already opened "duplicated" files.
  3. When PrimGen2 opened the file in the 3D editor, the corresponding file tab was not selected.
  4. The menu key (from the keyboard) did not work on the file tree.
  5. The menu key (from the keyboard) did not work on the 3D view.
  6. Wrong singular / plural use for the word "duplicate".
What will the next release 0.8.24 deliver? Bug fixes*, more header validation features, usability improvements...
* oh dear..., I still need to reproduce some errors...
  1. Download the zip-Archive
  3. On windows, double-click "run.bat" to start LDPE.
  4. On linux/mac, you have to excecute the shell script "run.sh" to start LDPE.
Please note that this software is in the beta stage. Although, LDPE 0.8.23 was tested, there are already known issues  for this release. There is a potential risk of data loss.
  2. On linux/mac, you have to excecute the shell script "update.sh".
System Requirements:
Minimum System Requirements:
  • Java Runtime Environment (JRE) 1.8
  • Operating System (32/64bit): Windows [XP; Vista; 7 or newer], Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: 4GB
  • Video-Memory: 512 MB
  • Free Disk Space: 100 MB
Recommended Requirements:
  • Operating System (64bit): Windows 7, Mac OS X [>=10.6], Linux [e.g. Ubuntu Linux >=10.4]
  • RAM: >4 GB
  • Video-Memory: >=1 GB
  • Free Disk Space: 512 MB
java -d64 version
[Wiki] Table of Contents / Main Chapters - Nils Schmidt - 2016-08-31
I am writing new content for a wiki :)
Currently, my table of contents has the following main chapters.
  1. About LDPE Introduces LDPE - why I built it and what it can do
  2. The LDraw™ File Format Explore and understand the LDraw library standard
  3. Setup Guide / Getting Started A step-by-step guide to install and run LDPE
  4. Basic Usage Learn how to use LDPE
  5. Configuration Customise the program settings
  6. Advanced Usage Learn how to master LDPE
  7. Sourcecode Study LDPE's algorithms and datastructures
I will focus on 3,4,5,6 first, then 2, 1 and finally 7.
I expect that it will take about 3-4 months of time to get a decent result [ there will be some winter holidays :) ]...
Nevertheless, I'll try to fix some bugs and release new versions as long as they are not reinventing the wheel.
Leg godt
Nils
RE: [LDPartEditor] 0.8.23 Beta Released (Context menus / LDU->stud / Async header check) - Philippe Hurbain - 2016-09-01
Sorry to disturb you from your (useful!) documentation work, but it seems there is a problem now with 0.8.23: the Merge/split->Set X,Y,Z window appears only with a single vertex selection, it no longer works on a multiple selection (eg. to snap a selection on a plane).
(tried with 0.8.21, the oldest version still available on github, it has the same problem. But I am sure it used to work!)
[Bug] Set X,Y,Z works only with one single vertex. - Nils Schmidt - 2016-09-01
(2016-09-01, 13:22)Philippe Hurbain Wrote: Sorry to disturb you from your (useful!) documentation work, but it seems there is a problem now with 0.8.23: the Merge/split->Set X,Y,Z window appears only with a single vertex selection, it no longer works on a multiple selection (eg. to snap a selection on a plane).
Thank you for this bug report! :)
I already fixed this issue (it took only 30 minutes).
I will release 0.8.24 in the next days (which will feature a little bit faster program start and a few bug fixes).
