Best way to help part author volunteers to meet part requests? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: Best way to help part author volunteers to meet part requests? (/thread-16479.html) |
Best way to help part author volunteers to meet part requests? - Neil - 2015-05-20 Greetings LDraw Friends, Aside from providing links to BrickLink/BrickSet images, is there anything I can do to help part author volunteers to meet part requests? For example, does a part author need to physically have the part and 3D-scan it? Such as Sabine's hair (from the Ezra Speeder Bike set): http://www.bricklink.com/catalogItemPic.asp?P=18858pb01 http://cache.lego.com/bigdownloads/buildinginstructions/6131809.pdf Thank you, LegoSW Re: Best way to help part author volunteers to meet part requests? - Max Martin Richter - 2015-05-20 For easy shaped parts it's enought to have correct measures. For complex parts you should one the part and you should be able to 3D-scan this part OR this part is available in LDD, If so, you can extract the geometry there and rework it, that it matches our standards. /Max Re: Best way to help part author volunteers to meet part requests? - Damien Roux - 2015-05-20 High resolution pictures taken with a perfectly orientated angle are always welcomed for patterned parts. And sometime it's a pain to find them on the net if one doesn't own the part. Re: Best way to help part author volunteers to meet part requests? - Gerald Lasser - 2015-05-21 I always appreciate a hi-resolution scan of the sticker sheets, Printed part etc., 600 or 1200 DPI would be perfect. A photograph never shows the proper dimensions (especially of stickers) respectively distorts the proportions. Re: Best way to help part author volunteers to meet part requests? - Neil - 2015-05-21 Would it help any of you volunteers if I purchased pieces and had them sent to you? For example, I could buy the Sabine Wren minifig hair and send it to you so that you could 3-D scan it: http://www.bricklink.com/search.asp?itemID=132056&colorID=63 |
